I'm new to the DS II world and really had never seen one close up before I bought this boat. I have 3 questions maybe you can help me with.
1. The boat has a Tabernacle , the bottom of the mast that goes thru the deck and has had a few layers of putty or who knows what added.
When I clean this out, should I add a bead of silicon or what?
Heres a pic.
[This image (547) is no longer available]
Question 2. On the bottom of the hull , on each side of the Cboard are metal plates. are they to protect the hull as pressure is applied from the board? or what. Should I remove them and rebed the screws? The glass around them is chipped and may also get a layer of glass. Heres a pic:
[This image (548) is no longer available]
Question 3.
There is a galvanized pole with a crotch on top. It connects to the gudgeons on the hull. The mast sits in the crotch and its used for towing the boat. I towed the boat home about 70 miles with no problems. The last owner said he trailered the boat from NJ to Mass. a few times a year and never had any problems. please look at the pic and let me know if you think this setup will hurt the hull or if you think its not strong enough . I beat the welds with a hammer to see if they would break before I towed the boat, and no problem.
[This image (549) is no longer available]
Thanks in advance for your help.
