I’m fixing some cracks around the front of the center board, on the hall. I read through a bunch of the other forum notes. My plan is to use fiberglass mesh, and vinyl resin to build up and fill in the gaps where I ground down. If you zoom in on the spot towards the front, you can that it looks like I am almost through the resin entirely. You folks think I should go all the way down to the mesh, or should I stop where I am at and do the glass and resin work? I’m open to any suggestions about how to build up around the plate screws as well.
Bonus question is about the antifouling paint. We are going to repaint bottom of the boat antifouling and the free board as well later the anti-paint seems to be pretty solid on the hull. My plan presently is to do a light sanding and then repaint with antifouling. Or, maybe I need to sand, prime, antifoul?
Hope folks find the surgical gown on the boat as amusing as I do.
Geoff
Baltimore, MD
