More on how this boat is doing as things develop.
This is a drawing not exactly to scale, but it does show the two sets of guy wires and the two sets of spreaders, one high and one middling.
tomodda wrote:The upper diamond is called jumpers or diamond stays. Get rid of them.
I'll write up why you don't want em later today, but look up jumpers on this forum. You can safely dump 'em.
GreenLake wrote:I've removed that upper diamond a number of years ago without ill effects. Nobody seems to know why the original designer or builder thought them necessary.
However, if either of the two lower spreaders is damaged or missing you should be sure to repair or replace it. Your drawing shows the shrouds (lower stays) as straight lines, but the spreaders should be long enough to force a bit of a corner. Presumably that's just the way you drew them, not the actual configuration, but just in case I wanted to mention it.
PS: I've moved this post to the "Rigging" section and took the liberty to edit the subject a bit to make it clearer to anyone reading this what we are discussing
GreenLake wrote:Let's make a new thread in "Repairs and Improvement" on the Centerboard issues. (You would have to do that, there's no moderator tool to handle posts that combine topics)
I get it that you might like to discuss your boat top to bottom in one thread, but having multiple subjects in a thread works against others learning and finding out about specific issues.
