Missing tabernacle pins
Postby darkstream » Wed Aug 28, 2024 8:50 pm
My mast has a tabernacle. The two pins are missing. Are there any recommendations on fashioning or buying new pins? I saw that DR Marine has something http://www.drmarine.com/proddetail.asp?prod=DR2151P that may fit (1/4in x 3.5in) for ~9.50 each. I saw a post here where someone used SS bolts from the hardware store and drilled holes for pin locks. Unsure if that was meant as permanent or temporary. A friend recommended a hitch pin from tractor supply but I haven't found one that is both 1/4 inch diameter and longer than 3 inches. Any opinions are welcome!
3176
darkstream
Re: Missing tabernacle pins
Postby GreenLake » Sun Sep 01, 2024 9:41 pm
If I can eaaily source something compatible locally, I usually go for it. Otherwise, I get it from DR Marine to support a business that stocks DS specific stuff. I might agonize a bit over some expensive item but not something at this scale. My 2 cents.
Also, if in doubt I'd call Rudy before placing an order. Great service.
Postby darkstream » Thu Sep 05, 2024 9:50 am
I also noticed a missing forestay pin. I was able to speak to Rudy and he has me sorted. Thanks for the direction.
darkstream
Postby GreenLake » Sun Sep 08, 2024 2:29 am
Glad it worked out. Be sure to get an extra or two. They like to disappear at awkward moments on the ramp. Don't ask me how I know :)
Users browsing this forum: Bing [Bot] and 21 guests
