mast step 1966 DS1
mast step 1966 DS1
Postby Chincoteague » Sun Oct 10, 2021 10:21 am
I am considering a 1966 DS1 that I am looking at on craigslist. I am confused about the mast step. The owner says that on this boat the mast steps on top of the cuddy. The 1966 DS Manual on this site makes no mention of that setup and instead shows the pass through keel stepped setup. Was this the year of a change? The pass through keel step looks like a pain single-handed. I have looked at the various ingenious solo stepping rigs in this forum. The owner of this boat says that even though his is stepped on top he has still always had help to put it up. I want to be sure that I can do this by myself. Thanks for any thoughts.
https://philadelphia.craigslist.org/boa ... 96238.html
Chincoteague
Re: mast step 1966 DS1
Postby hsumralljr » Sun Oct 10, 2021 1:20 pm
The owner, current or previous, has installed an optional mast tabernacle. The tabernacle is a hinge that installs into the mast (the mast is cut in two pieces for this) just above the normal deck level. The tabernacle makes it much easier to raise the mast single-handed. If you do a search on tabernacle you'll find a lot of information about it. A mast tabernacle is not recommended if you plan to keep the boat on a mooring.
Herb Sumrall, Jr.
Baton Rouge, LA
DS1 #3235
DS1 #2844
hsumralljr
Postby Chincoteague » Mon Oct 11, 2021 9:00 am
Thank you Herb. I didn't understand before that all stock masts are solid and all hinged are after-market. I'm seeing now that mast raising and hinged vs solid is thoroughly discussed in this forum. I will be reading up on that but thanks again for your word to this new forum user. This forum (and the DS Assoc) is one of the reasons Daysailers are high on my list of possibles as I hunt a used boat. David
Chincoteague
Postby Vanalien » Tue Oct 12, 2021 1:32 pm
Chincoteague wrote:all stock masts are solid and all hinged are after-market.
Later models of the Daysailer came with a stock tabernacle setup and hollow mast. My 25th Anniversary DS2 (built in 1985) has a stock hollow mast and tabernacle.
If these are features are important to you, you might want to keep looking.
Steve
Little Canada, MN
Vanalien
Postby GreenLake » Tue Oct 12, 2021 2:45 pm
Just to eliminate some confusion here. All masts for the DS are hollow. The poster wrote "solid" in order to express that the mast is a single piece.
Postby Fly4rfun » Tue Oct 12, 2021 11:10 pm
can and is it recommended to fill the mast with foam?
can someone expand on why is it bad/not preferred to have a tabernacle if boat is on a mooring.?
"Sail Aweigh" 1966 DS1 #2675
Fly4rfun
Postby GreenLake » Wed Oct 13, 2021 1:05 am
Foam filling the mast prevents it from filling with water in a capsize. I don't know if you really need to fill more than a "plug" at the head and foot, assuming everything else is sealed.
A tabernacle is a moving part that can be under stress from the constant load changes on a mooring. Here's a thread about what it looks like when a tabernacle fails.
That failure mode is not available for the single-piece mast.
Users browsing this forum: No registered users and 62 guests
