This motor has given no trouble previously. When running with a boat load it works perfectly except if you advance the throttle past the mark "FAST" about another 1.4 inch the motor will suddenly start to race. Moving the throttle back to "FAST" it goes back to normal. Gears change perfectly and it does not slip out of gear. I pulled the prop. I inserted the shear pin in the prop slot and I found I can turn the bearing with a pair of pliers on the shear pin. Does this indicate that the rubber hub around the bearing is worn and needs replacing? Any ideas would be appreciated. Thanks.
Russ (ve6vk-at-telusplanet.net)
