Does anybody have pics on how to install the reefing hook from D&R? No instructions, and it doesn't seem to fit anywhere on the gooseneck.
Thanks.
GreenLake wrote:Not all goosenecks are the same. What does yours look like?
jalmeida51 wrote:If you remove the vertical clevis pin, this will separate the goose neck from the slider for the boom downhaul. Install the reefing hook with the vertical clevis pin. reassemble the goose neck to the down haul slide. Install new cotter pin. The picture is upside down which may have confused you. I have never used the bracket with the disconnect pin. I have always used the pin on the goose neck to attach the tack of the mainsail. Really don't know what the bracket is used for other than the hook is welded to it.
Users browsing this forum: No registered users and 36 guests
