Downhaul Cleat Solution
Re: Downhaul Cleat Solution
Postby GreenLake » Mon Feb 01, 2021 7:55 pm
Any way you can attach a downhaul would be fine. My sail is cut so the gooseneck has to go to the stop and the downhaul tied in that fixed position even for low wind (additional luff stretching for higher winds via Cunningham). So my downhaul isn't particular about how it's attached to the gooseneck, as it's a simple fixed attachment. (The gooseneck happens to be a SS part in my case and has a SS eye. A hole drilled somewhere would have worked just as well.
Return to Racing/Performance
