Gary:
I agree with GL - use what you have. Fiddle block isn't ideal, but will do with some careful measuring. One caveat - I find those blocks with V-shaped jam-cleats to hold the end of the rope next to useless. Can't see form your photo if that is what you have, but be aware that there will be at least 50 lbs of force on the rope when you are sailing in any sort of breeze. It's all bearing on e one short piece of the cover of the rope - so rope will soon fray - and it's a real pain to unjam it from the V when you want to adjust the vang.. it's at a bad angle, think of where you sit when you're sailing. Anyway, for what it's worth, my "ghosting around" photo from another thread has a pretty clear view of my vang, I resized it here for you:
- 20:1 Vang
- DS1-37 (2).jpeg (154.38 KiB) Viewed 35729 times
This is a 20:1 vang, like in GL's diagram above. I hope this helps illustrate what he's written about re; distances in the previous post. At max extension, the two cascade blocks (on top) will meet - this happens when you are at a dead run, mostly. Of course, you want a bit of vang tension even at dead run, so not that likely to happen. More usual is the two bottom blocks touching when you have the vang really cranked on, beating upwind.
Please remember for your measuring, everything depends on how high your boom sits. I try to keep the gooseneck exactly at Band #2 - in other words the class-legal minimum height off the top of the cuddy. Check out the DS Association Specifications and measurements guide, fi you haven't already:
https://www.daysailer.org/resources/Documents/dsbylaw3.pdfI have the bands laid out in sections 7 and 8 marked off on my mast and boom using electrical tape. Keeps me semi-sane as I fiddle with sail adjustments. Not that I'm racing, but at least I know I'm "in the ballpark" of what intended for the Daysailer.
Anyway, good luck and please keep asking questions!
P.S. Ebay and used boat part sites are your friends for cheap blocks - get yourself some "oldies but goodies," in other words name-brand blocks at a discount, Schaefer or Harken for instance. For example:
https://www.nandjmarine.com/store/doubleRight now they're selling 2-inch Schaefers for $25, a steal. You'll need to buy some shackles, but you'll still come in under $100. Buy some good single-blocks for top part of cascade, some Dyneema line... You'll be around $150 for a 20:1 cascade. And as someone else pointed out, you don't necessarily need 20:1. This is all just food for thought.
