Cockpit trim question (cut or remove)
Re: Cockpit trim question (cut or remove)
Postby GreenLake » Mon Jan 27, 2020 10:36 pm
Rubrails are pretty durable, even if the no longer look pristine. (Good way to clean is with scotch pad or magic eraser). They will pick up dirt/rust when doing their job, but unless you are trying to restore your boat to optical perfection, I would try to re-attach them rather than replacing them.
Talk to D&R Marine, they may have the end pieces (shoes) that hold the rail against transom. If not, you could improvise with square tubing.
Postby jalmeida51 » Tue Jan 28, 2020 3:14 pm
Try using lacquer thinner on a rag. Been cleaning my rub rails for several years using it. It really removes the built up dirt. Try it on a small section first.
jalmeida51
Postby Cliff » Tue Jan 28, 2020 3:39 pm
I think calden found a good solution for keeping the coamings with a hiking pad. Pic from his gallery.
hiking pad.pdf.jpg (15.37 KiB) Viewed 5810 times
Cliff
Cliff
Users browsing this forum: No registered users and 57 guests
