Cockpit trim question (cut or remove)
Re: Cockpit trim question (cut or remove)
Postby K.C. Walker » Mon Dec 16, 2019 10:41 pm
This may not win any race but c'est la vie. :D
Postby GreenLake » Mon Dec 16, 2019 11:32 pm
Sitting on the lee side is something I only do in light / very moderate winds when I have crew that can balance the boat. If I'm by myself in any breeze, I'd be afraid that any good gust would put the mast horizontal. Sheets: I'd hold both in one hand, amazingly you can still adjust them relative to each other to some degree, if you allow your hand to move in 2-D or even 3-D and not simply along a single line. (In many conditions I would simply cleat the jib).
I like the coamings for conditions where we take water over the bow: it tends to not run into the cockpit as it comes aft past the cuddy.
Postby K.C. Walker » Tue Dec 17, 2019 12:20 am
Yes, when I first lowered my coamings flush to the deck, I would get water coming into the cockpit right past the cuddy as water would come over the front deck. I added little minicell foam coamings angled away from the cuddy to the rail and that did the trick to divert the water.
Postby Cliff » Thu Dec 19, 2019 1:00 pm
K. C.
You're making my point!
Cliff
Cliff
Postby K.C. Walker » Thu Dec 19, 2019 1:33 pm
Cliff wrote:K. C.
Maybe so! :-)
Though, in my situation, the water was coming over the windward side of the cockpit from spray on the foredeck. On nice windy days, when I am happy to be hiked way out on the side deck, toes in the hiking straps, and without the coamings digging into my legs, my little extra coamings also help keep my butt dry. :-)
Postby Cliff » Mon Dec 23, 2019 8:25 pm
That may be the way to go but GL has got me feeling guilty not to cut them down. Mine are somewhat historic with a bronze grab fitting through the coming for the sheet-- there is no adjustment of where the sheet can be fastened. I know this should be remedied.
Oh well have a Merry Christmas in Conn.
Cliff
Cliff
Postby GreenLake » Mon Dec 23, 2019 9:21 pm
You can always mount some cleats on the CB trunk.
Postby Cliff » Tue Dec 24, 2019 12:48 pm
No, I'm referring to the no adjustment position of where the sheet is hauled. Will want to install a sliding pulley adjustment.
Cliff
Cliff
Postby GreenLake » Tue Dec 24, 2019 1:19 pm
Ah, sorry, read too fast.
Interestingly my sailmaker's instruction for my jib assumes barber inhaulers but a fixed position for the jib fairlead.
I found that counterintuitive, but I wasn't going to argue.
Postby Cliff » Tue Dec 24, 2019 2:18 pm
A pic may explain it.
Starboard Coming.JPG (184.79 KiB) Viewed 16183 times
Cliff
Cliff
Postby GreenLake » Tue Dec 24, 2019 6:12 pm
Nice. These look like combination thru-coaming/cleats.
You are right; they don't allow fore-aft adjustment, but if I believe my sailmaker, he felt that in/out adjustment was more important.
That's an if.
Postby Cliff » Tue Dec 24, 2019 7:06 pm
I yield to your experience since I've never had the Barber Adj. Assume that having both is now standard.
Cliff
Cliff
Postby GreenLake » Tue Dec 24, 2019 9:24 pm
Experience seems to indicate that the effect of the inhauls is noticeable. In the right conditions: upwind 6-12 knots. In the middle of that range the sheet can be hauled in to as much as 18" form centerline, but 0" if well outside that range, or reaching or downwind. Some intermediate setting for the transitions at the low and high end of the range. Easy to jury rig with a loop of rope for testing.
However, nothing beats having a dedicated crew person (elf) doing the jib trim.
2717
Like in this picture going on a close reach while reefed.
Postby Cliff » Wed Dec 25, 2019 2:19 pm
Is that elf named Barber?
Cliff
Cliff
Postby GreenLake » Wed Dec 25, 2019 3:20 pm
