I was looking for some info / guidance on correcting weather helm and this post, particularly this quote seemed like a good starting point for my questions / starting a dialogue.
The North Sails Daysailer Tuning Guide tells you that the distance between the top of the mast and the top of the transom at the very back of the boat should be between 24'11" and 25'1". You measure it with a tape measure pulled aloft by the main halyard.
The result should be that sailing in 8-10 knots of breeze, going upwind, there's not a very strong force on the rudder, so the boat is balanced. If you need to pull hard on the tiller in those conditions, your boat would be imbalanced with too much "weather helm", which is like sailing with the parking brake on.
So, raise the mast, adjust the mast rake until you get the target numbers (read tuning guide for details of how to measure). Then, fix the mast step, go sailing and see whether your boat is balanced. If too much weather helm, you can let the mast come forward a bit, if lee-helm (you need to push the tiller upwind) you can let the mast come back a bit.
Have followed the NS DS Tuning Guide these past two years and have gotten my mast rake (to between the 24'11" and 25'.1" target numbers) and shroud / stay tension measurements to recommended.
Recently had one of the Club's sailing instructors sailing with me as crew in 8-12 knots with gusts and asked her to take the tiller for awhile as I wanted to see how some of the changes I made for jib and some other controls actually worked. She had the tiller for about 30 seconds and said "OMG you have SO MUCH weather helm that I don't want to sail
this boat today, would you please take the helm back?"
Last year was the first year I sailed this boat, and with this year have now sailed my DS maybe 9 times in total, certainly have felt the weather helm, but I guess not having ever sailed a "balanced" helm DS never thought of it as a problem.
My mast is keel stepped into a track (see picture) and the front of the mast does come out and touches the front edge of the mast partner part of the deck where it exits the cuddy.
- mast step.jpeg (30.63 KiB) Viewed 16065 times
I've been re-reading up on Center of Effort, Center of Lateral Resistance, rig tuning, and sail adjustments to reduce weather helm etc. and I think that I have a rigging problem, rather than a sail adjustment issue. Yesterday sailing in somewhat lighter winds than previous week, I had to move my traveller
far to leeward to noticeably reduce the weather helm, but then felt very underpowered and slow. Talk to some others that raced (and finished significantly ahead of me... more ahead than usual
) and they didn't touch their travelers yesterday. One person suggested that I move the mast butt back a notch, which would lean the mast forward / have less rake as a suggestion.
Would tightening the front stay more also help move CE forward? Forget what tension I have the stay at now, but I do have a Loos tool so I could check.
Any thoughts would be appreciated.
