Hi,
Looking for some advice on hot to protect the strapping/risers on the floor boards from friction. I refinished my boards two years ago using Spar varnish; it's lasted well on the tops of the boards, but there is wear on the strapping pieces where they make contact with the fiberglass hull. Originally I had put foam weatherstripping under the risers, but the adhesive released and the foam retained water (which I should have anticipated).
I'm thinking of sealing the bottoms and sides of those pieces of wood with epoxy instead of varnish and tacking rubber D channels in place. Any thoughts or other suggestions?
Adam
