Pierce56 wrote:I'll try and post a picture tomorrow. I think my current chainplate is a little more aft. Between the rivet and the O in O'day.
Shagbark wrote:DM, what's the red line around the horn going to?
TIM WEBB wrote:DM, why the double line for the jib DH?
GreenLake wrote:TIM WEBB wrote:DM, why the double line for the jib DH?
Tim, clearly, DM is flying a butterfly rig, with two forestays and one jib poled out to SB and one to P. He's ready for the trades in the Pacific.
DigitalMechanic wrote:GreenLake wrote:TIM WEBB wrote:DM, why the double line for the jib DH?
Yep I could not afford a spinnaker, so downwind I just fly the new and old jib at the same time, one on each side of the boat. I also installed little wings on each side with flaps. With enough breeze the boat comes out of the water and turns into a seagull.![]()
Just kiddingIn that picture the boat is sitting on the trailer in the driveway. Both ends are tied off there for storage because it is not in use/rigged. When the boat is rigged, one of the ends is lead fore through a micro block by the stemhead and then attached to the jib. When the jib is up, I clip it off on the mast. That allows tacks/gybes to lift the foresail up and over the section of calamity on the mast where things like to snag. When the jib is down, I tie it off on the horn cleat by the starboard chainplate, and throw the excess into the cuddy.
Alan wrote:There is a simple solution. I first read about it in John Vigor's The Practical Encyclopedia of Boating. The jib tends to catch on stuff ('calamity") on or near the mast while you're tacking. If you run a tight line from the stemhead to the lower part of the mast, the jib will ride over it during tacks and not get caught.
Sounds like DM is getting double use out of his jib downhaul line by having it work for both purposes. Pretty resourceful, I'd say.
Users browsing this forum: No registered users and 98 guests
