Cuddy Trim Edge Replacement
Re: Cuddy Trim Edge Replacement
Postby talbot » Mon Apr 25, 2016 1:46 pm
Good advice.
For the record, I installed plugs on my cuddy drains, same as on the transom. The mast tabernacle is sealed with rubber marine hatch tape. The through-hull for the CB uphaul is sealed when the boat is underway. So I'm pretty sure the only source of water in cuddy between trips is through the open-cell foam weatherstripping. I'm drying out in Arizona on travel for work right now, but I understand it's pouring back home in Oregon. So I'll have a chance to check it out this week. The boat was dry when I put it away on Friday.
Postby SUNBIRD » Mon Apr 25, 2016 3:12 pm
I put corks in the drain holes for the cuddy, at least those scupper flaps hide the corks from the sun.
Rod Johnson, "SUNBIRD"
1979 DS II, # 10201
SUNBIRD
Postby jeadstx » Tue Apr 26, 2016 12:53 am
I used some flexible sealant around the mast to keep water out of the cuddy from that source. I know water can get in thru the gaps between the hatch and opening, also the drain holes. Only seem to have a problem in very heavy rains.
Users browsing this forum: No registered users and 33 guests
