GreenLake wrote:I find that keeping the boom at its standard height (resting on the existing stop) clears even tall crew comfortably.
For any topping lift on a small boat like a DS (where you can manually support the boom while adjusting it) I find the use of a block on the mast unnecessary overkill, and the resulting "return" line down the mast totally unnecessary. If you want convenience, put a block on the end of the boom and a cleat a few inches in from the end. (Further in, if you ever plan on lifting your boom to very steep angles).
With a Blake's hitch (and without planning to lift your boom to crazy angles) there's no need for any hardware beyond an eyestrap near the mast top. I would make sure that you use a line that has enough friction. For example, while 2mm or 3mm AmSteel is strong enough to hold much of your boat, let alone the boom, it's very slippery.
TIM WEBB wrote:(Almost) the same number of steps, just in a different order....With the swivel block/cleats,... and I can do both while seated in the cockpit.
Agreed on low-stretch halyards, but I've never had a "gust stretch" plain old Sta-set or the like.
DigitalMechanic wrote:...Well, after talking to Tim Webb, I know I am not the first one to discover it, lol. So, I put a flip-flop micro block up by the stem head and a horn cleat by the chainplates (once again courtesy of my good friend Tim's advice), and for whatever reason (maybe beer?) I cut the line for it to short. So, even though I screwed up, I still wanted to play around with the new jib downhaul, so I was looking for a place to tie the aft end of it off. Well, apparently I cut it just short enough to come back to the mast. I put a piece of the line I trimmed away from the TL around the mast just above the horn cleat (for Cunningham) that clears all the stuff my jib sheet like to get snagged on. Well, with that in place, the jib sheet crosses every time due to the lift that occurs, bringing the jib sheet up and over all the "snagables". The only downfall is that there is a trip hazard up on the foredeck, but with the way the boat is rigged now, I should not have to go up there unless setting up or tearing down the boat.
Thanks for the shout out DM, but I'm afraid I can't take credit for the idea. I stole it from a previous guy, who prolly stole it from somebody before him, etc etc etc.
DigitalMechanic wrote:itguy,
On the topping lift... The PO of my boat mounted a relatively large block for the application halfway between the shroud tangs and the top of the mast (actually this was probably for a spinnaker??, but he turned it into a topping lift). Doesn't really work that well, and have traditionally bastardized it in favor of just dropping the boom and sail in the boat. About a week or so ago, I got a micro swivel block and put it on an eyestrap (spare parts) at the top of the mast. It uses a carabiner (from the old TL) attached to some 50ft FSE Robline 3/16 that I got on sale, and ties off on a cleat on the side of the lower part of the mast. The system did not make sense to change because it was mostly already there, just needed the block to be at the top of the mast. With that said, again on the trailer, with the main sail up... slack it off so the main is not impeded from filling with wind. Then tie it off. When I drop the main sail, the boom drops a few inches, but there is still pretty good head room without having to adjust anything. However, if you need to adjust, with your setup you can crank the boom up if you like. You will just have to re-adjust the TL slack again next time you raise the main.
