Unless you go to a motor that is capable of getting the DS on a plane, you don't want to play in currents like that. As for tides, they do have slack periods
Madcitysal wrote:Tim,
The Honda description for the Air cooled 2,3 hp states that "there is nothing to get clogged." This is contrary to your opinion. Do you feel their description is "suspect?" Thanks posting.php?mode=reply&f=11&t=3522#
GreenLake wrote:Tim, are these cooling ports where water is aspirated, or merely exhaust ports where the exhaust exits? In the latter case, there would be no chance for clogging.
The sales literature merely states that there's no water pump to clog; the manual does not mention anything about exhaust cooling, but technically, if there were ports where water is aspirated it would not be a water pump
talbot wrote:Greenlake -- you mean "charge" the batteries, don't you?
talbot wrote:Question about rinsing a 2hp Honda "after every saltwater use."
talbot wrote:Oh, man. Why do I have to keep learning new stuff? Since getting this last boat, I have had to learn . . .
--structural fiberglass repair
--osmotic blister restoration
--VHF radio protocols
--GPS navigation
--12v electrical wiring
--aluminum refinishing and painting
--steel refinishing and painting
--trailer axle replacement and maintenance
--small dog PFD fitting and behavior
Now small engine maintenance. Will it never end? Will I never get to just be an old man, stuck in a rut, telling the same stories over and over? I didn't even want another boat. My wife made me get it. What was she thinking?
Users browsing this forum: Google [Bot] and 117 guests
