Hello,
Another new Daysailer 1 owner here. I'm in the process of refurbishing my 1967 Daysailer. Just took the centerboard off to inspect it and found it is fiberglass and hollow. There is a small hole drilled on one side about a foot from the tip of the board and I found that the centerboard was about half filled with water. Is this a common design? I'm assuming that the intention is to increase ballast slightly?
Ted
