Centerboard Troubles
Re: Centerboard Troubles
Postby TIM WEBB » Wed Sep 11, 2013 10:53 pm
GL, I think what John means is that some DS2's have a CB pivot bolt, and some have wedges/plates/pivot pins that hold the CB in position. Dunno if the pivot point is in the same location for both. I'm not familiar enough with the wedge system to know if the boats with that system use a through-board pivot pin or not, or if it's in the same location as the pivot bolt boats. ChrisB?
Postby GreenLake » Wed Sep 11, 2013 11:11 pm
How could they be class legal if geometry is different for some angles? How would they fit the same slot?
Postby Alan » Wed Sep 11, 2013 11:58 pm
I've got a wedge DSII, so I can tell you that there is a through-board pivot pin, but it doesn't penetrate the sides of the centerboard trunk like the pivot bolt on the earlier models. It only goes into the wedges.
Postby GreenLake » Thu Sep 12, 2013 12:43 am
But the place where the board pivots is the same in the plane of the board right?
Postby Alan » Thu Sep 12, 2013 9:33 am
It makes sense that they would all have the same pivot point, but all I know about from my own experience is the wedge design.
Postby OldandBusted » Thu Sep 12, 2013 11:45 am
Here are some photos:
CB 3.jpg (157.21 KiB) Viewed 15592 times
CB 2.jpg (214.9 KiB) Viewed 15592 times
CB 1.jpg (215.52 KiB) Viewed 15592 times
OldandBusted
Postby jeadstx » Thu Sep 12, 2013 12:45 pm
It does make sense that the pivot hole would be in the same place, but I have to wonder why D&R sells the DS1 CB with it's square hole and the DS2/3 CB without a hole drilled in it.
Postby kokko » Thu Sep 12, 2013 2:44 pm
Yikes! You need to grind out the cracks and fill it with a marine epoxy filler. You might want to cover it with epoxy and glass tape too.
DS1 Truelove
kokko
Postby OldandBusted » Thu Sep 12, 2013 6:02 pm
That's what I was thinking. Could these cracks have a large impact on performance?
OldandBusted
Postby GreenLake » Thu Sep 12, 2013 7:55 pm
U bet. Destroy the flow over the foil. Lots of drag and no lift...
Use polyester marine filler. Probably cheaper and cures faster. Try bulk up then sand a better foil shape before glassing
Postby OldandBusted » Thu Sep 12, 2013 8:24 pm
That would explain several problems and thank you! Is there a place to read more a out the correct shape/ dimensions for the foil?
OldandBusted
Postby UCanoe_2 » Thu Sep 12, 2013 9:29 pm
Your centerboard definitely did not come that way from the factory!
There are lots of threads on the forum about centerboard repairs. Here are links to mine, which are current this year:
http://forum.daysailer.org/forum/viewto ... =11&t=4266
http://forum.daysailer.org/forum/viewto ... =11&t=4356
http://forum.daysailer.org/forum/viewto ... =11&t=4374
http://forum.daysailer.org/forum/viewto ... =11&t=4432
http://forum.daysailer.org/forum/viewto ... =11&t=4469
http://forum.daysailer.org/forum/viewto ... =11&t=4466
Also see my photo gallery.
http://forum.daysailer.org/forum/galler ... bum_id=120
There is a dimensioned drawing of the centerboard profile (side view) in the DS class rules here on the forum.
The stock cross section is pretty inefficient. The ideal is supposed to be a NACA airfoil, developed IIRC in the 1920s or 30s for slow speed airplanes. You can do a web search and find lots of information for creating one of these shapes. Since we live in the Computer Age, most of the methods you find will involve computers in the guise of various programs or Excel spreadsheets.
Here is one from Duckworks:
http://www.duckworksmagazine.com/07/how ... /index.htm
All that seemed overly complicated to me. After all, in the 1930s before computers were invented, draftsmen plotted these foil shapes using compasses, straightedges, French curves, and wooden battens. I used a graphic solution to make a template for the foil shape of my board. The critical dimensions are chord length (fore-and-aft width of CB), leading edge radius, thickness of board, and distance of maximum thickness from leading edge. Unless you are racing it doesn't have to be perfect -- mine certainly is not. Almost anything would be an improvement over the very flat factory shape. As you may have read elsewhere, it is important for the trailing edge of the CB to be squared off about 1/8" thick, and not tapered.
http://forum.daysailer.org/forum/galler ... ge_id=1537
1537
My new foil shape turned out almost 1/2" thicker than the stock CB. I spent a lot of money on epoxy before realizing I could build up the thickness with wood strips. Also, I filled in a lot of the missing pieces with epoxy putty, about $6 a tube in the plumbing department at Lowe's. I probably could have saved a lot of time and money by building a new CB. You may decide the same depending on your skills and tools available. There is another recent thread on building a new CB, but I am too tired and cross-eyed to find a link at the moment.
You are fortunate to have lots of helpful people on this forum with lots of knowledge. It is a great resource.
-- Mark Twain
UCanoe_2
Postby GreenLake » Thu Sep 12, 2013 11:18 pm
This thread has lots of my input : Severely cracked leading edge of centerboard DSII
Postby OldandBusted » Fri Sep 13, 2013 7:44 am
Wow! You guys are amazing and I couldn't agree more about this forum. Thanks to everyone!
OldandBusted
Postby OldandBusted » Mon Sep 16, 2013 9:24 am
By the way, what is a PO?
OldandBusted
