- This is a tentative setup of blocks and cleats for a Doyle Utility Power Sail. The bow is to the left in the photo. The cheek block on top of the coaming is a stand-in for an autoratchet block.
- tentative UPS sheet blocks.jpg (181.88 KiB) Viewed 27024 times
Thanks once again for the advice, gang.
I've been mulling over Chris's and K.C.'s solutions. Does this look workable to you guys? In the photo above the bow is to the left. I've set up a swivel block (coincidentally, the same brand and model as Chris's and sourced from Duckworks) and a cheek block and a cam cleat and some line, all left over from abandoned ideas.
The swivel block is set up almost the way I read Chris's description, but outside the coaming instead of on top of it.
The cheek block is a stand-in for an autoratchet cheek block because I don't have them yet. I'm thinking of Ronstan 57 mm, or maybe Harken 55s because the ratchet release load is adjustable.
The cam cleat is maybe overdoing it, but I've got two of them already, so what the heck.
The line is 1/4-inch Sta-Set because I happened to have it, but my creaky fingers are definitely leaning toward 7 mm Bzzz.
And I want to make the Dyneema soft shackle just for the fun of it. Still got to pass the time until April...
I'm hoping to keep lines out of the cockpit for now, partly because there's less of a tripping hazard and partly because there will be two to four people in the boat. Seems to me that this setup will do that, and also give a 180-degree turn around the autoratchet.
Make sense?
