Annapolis Discoverer 17' Refurb
Postby calden » Mon Apr 28, 2008 12:07 am
Nice job!!! Sweet!
Carlos
DS I #1653
calden
Beautiful
Postby ktcdvm » Mon Apr 28, 2008 8:46 am
Your paint job puts me to shame. I'll still send pix when I get them but man now there's some embarrassment factor. Great work. Did you replace the rub rail? mine is very tired and ugly. Yours shines.
Kevin
Kevin
"Stewball"
Annapolis Discoverer #221
ktcdvm
Postby adam aunins » Mon Apr 28, 2008 3:50 pm
"Son of a gun!!!!" :D I'm glad that I have not painted my boat yet. I've read about using Rustoleum but I thought it was the non-rattle can stuff for deck chairs, tractors, and things like that.
adam aunins
Postby adam aunins » Mon Apr 28, 2008 6:15 pm
I just ordered my paint from Home depot. How many guarts did it take for you to paint your boat?
adam aunins
Postby algonquin » Mon Apr 28, 2008 10:29 pm
Absolutely Gorgeous !! :D I'll be starting my paint job in about a week or so. Your effort is quite inspiring. Brad
"Feather" DS1 #818
algonquin
Postby Discoverer138 » Tue Apr 29, 2008 9:53 pm
We used a 1/2 quart of the rusoleum black gloss for the bottom and 1 quart blue gloss for the hull. The white stripe is semi-gloss but same paint. We did three coats of the black and five coats of the blue. We thinned the blue out quite a bit so we would get a nice glossy smoothe finish. Wet sanded lightly in between coats. We were debating between paints, but definitely glad we chose the rustoleum. Very easy to work with and pretty inexpensive.
Discoverer138
Postby algonquin » Tue Apr 29, 2008 10:29 pm
Discoverer138 wrote:We used a 1/2 quart of the rusoleum black gloss for the bottom and 1 quart blue gloss for the hull. The white stripe is semi-gloss but same paint. We did three coats of the black and five coats of the blue. We thinned the blue out quite a bit so we would get a nice glossy smoothe finish. Wet sanded lightly in between coats. We were debating between paints, but definitely glad we chose the rustoleum. Very easy to work with and pretty inexpensive.
Really nice paint job. Did you thin the paint with thinner or mineral spirits ?
"Feather" DS1 #818
algonquin
Postby Discoverer138 » Tue Apr 29, 2008 10:42 pm
Yes we thinned the paint about 30-40% with paint thinner. If you do not thin it enough, it will not "flow" properly after you tip it. Thinning the paint that much, you do need to apply more coats. But it will look like glass when its done.
Discoverer138
Discoverer
Postby Nels » Mon Jan 10, 2011 9:45 pm
Hello Discoverer 138,
I have Discoverer 79 and also live in Norfolk. I've done some work on my boat, but it doesn't look as good as yours. Mostly sail out of Lynnhaven River and Willoughby.
Nels
Discoverer
Postby Nels » Mon Jan 10, 2011 9:48 pm
Nels
Great Job
Postby SDRIGGERS » Tue May 24, 2011 1:02 pm
Discoverer #138,
You have inspired me to refurbish my Discoverer, rather than continue with my "sail it until it falls apart" attitude. Thanks for chronicling your effort. I have soaked up every tip. I'll let you know how it goes.
Scott
Annapolis Sailboat Builders Discoverer #57
"Wind Dancer"
"For one thing, I was no longer alone; a man is never alone with the wind-and the boat made three." - Hilaire Belloc
SDRIGGERS
Postby Alan » Wed May 25, 2011 11:18 am
Discoverer 138,
Looks like the paint job was done three years ago. How has it held up?
Re: Annapolis Discoverer 17' Refurb
Postby Salty Dog » Sat Jan 19, 2013 11:42 am
This is a very nice paint job. I am inspired to paint mine DS. When he talks about "rolling and tipping". What is that process exactly. If someone knows. I'm afraid discoverer138 is no longer on line.
thanks SD
Salty Dog
Postby GreenLake » Sat Jan 19, 2013 8:23 pm
You have one person roll the paint with a paint roller.
That leaves little bubbles.
You have another person who uses a very high quality brush and, holding the brush perpendicular to the surface, very lightly passes over the paint to "pop" the little bubbles.
That's the "tipping". It has to be done immediately after rolling.
It will leave very faint brush marks, but much fainter than if you had brushed on your paint.
Correct thinning will allow the paint to flow just enough to take care of these marks so that they are pretty much invisible.
Postby Salty Dog » Sun Jan 20, 2013 3:31 pm
Thanks Green Lake
I'm glad I asked. That sounds alot less labor intensive than I had pictured in my mind. I thought I would need 5 or 6 friends helping.
thanks SD
Salty Dog
