more mainsail flotation
Postby jdoorly » Wed Feb 23, 2011 11:46 pm
I finished making my mainsail flotation device today, now I wait till the ice melts, and maybe a little longer, to test it. Here's some pics...
The foam: 16 pounds of bouyancy, 2" thick each side.
939
The nylon ripstop tube, with abrasion resistance and access to foam.
940
Mounted on the head of the mainsail.
941
Close-up of front.
942
How do ya like my artsy fartsy retro B&W pics and the Adams-esque play of shadow and light!
Postby ctenidae » Thu Feb 24, 2011 10:12 am
Nice job there. The floatation system is nice, too.
Formerly 28 cents
DS1 1114
ctenidae
Postby algonquin » Thu Feb 24, 2011 4:06 pm
Design - Exceeds expectations.
Fit and finish - Beyond reproach.
Artsy Fartsy B@W photography - Priceless!! :D :D
Very nice work Jay. It is a little to early to test it assuming you will probably be laying your boat over on its side to do it. Is that a sail slug sewn on in the last photo ? Brad
"Feather" DS1 #818
algonquin
Postby K.C. Walker » Thu Feb 24, 2011 5:38 pm
Nice design and professionally executed. Seems like your next step is to think of a catchy name for it, then commission a Chinese sail loft to make them for you and start selling them on eBay. You'll make a fortune!
Postby jdoorly » Thu Feb 24, 2011 8:56 pm
Gooorsh, thanks guys.
Brad, the mainsail slide is still attached to the mainsail but the vinyl has a slit to capture the slide and keep the flotation at the head of the mainsail. It takes less then a minute to attach to the mainsail or you can leave it attached. I hope to test it fairly soon, as I have a drysuit and much layers of fleece. However, the snow drift has only melted down to the gunwales at this point.
K.C., from your mouth (ummm fingerstips) to God's ear. But, first I'd like to check and see if it makes a 'stick in the mud' outa my mast, or not. How about calling it Jay's Wet Dream. Actually, I kinda like that for a boat name!
