hull repair
hull repair
Postby bitpyrate » Tue Jun 29, 2010 1:15 pm
I need to replace the plug on my Daysailer 3
iv included a picture showing both the original and the new on i bought form DR marine.
The outer diameter of the orignoal is 7/8"
however hte new one is 15/16"
Do i have to bore out the hole a little bit? I would prefer to by a better fitting one if anyone knows where i can get on. otherwise anyone have recommendations on how to enlarge the hole?
https://docs.google.com/leaf?id=0B4gIxJorRQ7RZmRmZmQ1ZjctNGE2OC00ZTMyLWIwN2EtYTY3NTg5ZmY1NWUy&hl=en
bitpyrate
hull repair
Postby ChrisB » Wed Jun 30, 2010 9:24 am
Had the same problem on my DS II. I had lost the "screw in" plug that goes into the flange on the hull. I ended up cutting the threads out of the inside of the flange (so it was smooth) and using a cork stopper instead of the screw in plug. I keep a spare cork in my toolbox but I have never lost the cork while on the water.
Chris B.
ChrisB
