center boom vs. end boom sheeting
Postby K.C. Walker » Sun Dec 13, 2009 8:57 pm
I've decided to change from center boom sheeting and go with end boom sheeting for next year. However, I noticed that at 2009 nationals the top 3 finishers used center boom sheeting. Also the juniors 1st place finisher used center boom sheeting. Because many of the former champions have used end boom sheeting, I guess there's no clear advantage either way for racing. I just thought it was interesting.
KC
Postby algonquin » Mon Dec 14, 2009 4:27 pm
Probably no real significant advantage with one over the other as long as you are using a boom vang with a decent purchase. Without a boom vang I would prefer mid boom sheeting over end boom sheeting as it offers more control over sail shape. The great equalizer is the boom vang. Brad
Vaadaaaa Boom !!
"Feather" DS1 #818
algonquin
Postby K.C. Walker » Mon Dec 14, 2009 5:08 pm
algonquin wrote:Vaadaaaa Boom !!
:lol: KC
Postby algonquin » Mon Dec 14, 2009 5:23 pm
There is an advantage to mid boom sheeting if you sail solo and need to sit forward to have easier access to your jib sheets. My previous boat used a boom vang with end boom sheeting. I would coil the extra main sheet line and place it over the tiller which helped to keep the area neat but I did have problems with access to this type of setup when I needed to be forward to adjust the jib. Brad
"Feather" DS1 #818
algonquin
Postby guido » Wed Dec 16, 2009 3:07 pm
KC,
Were the mid-boom rig winners using a traveler car or just mid boom from a fixed mount on the centerboard trunk?
guido
QYC DS Fleet
guido
Postby K.C. Walker » Wed Dec 16, 2009 6:29 pm
Hey Guido,
I can't tell for sure from the pictures if 2834 has a traveler but it's rigged as 4:1. On 2015 and 2028 I did spot travelers. 2015 took 2nd place and also won in juniors and is rigged 3:1. None of them is rigged stock and they all seem to be using nice big blocks. A couple of them are even using stock rudders, it appears.
KC
Return to Racing/Performance
