ctenidae wrote:Anybody find the extra length of line to handle an issue? I'll probably leave it rigged mid-boom either way, since I like the smaller number of lines, but just curious.
K.C. Walker wrote:Would it not be correct if you consider end boom sheeting with 2 lines at the end and one in the center as being 2.5:1 then 3:1 in the center would equal 1.5:1. If we are using the boom as a lever arm, and that it is at 1:1 at the end, then the middle would be half that at 0.5:1. So, to get the same mechanical advantage in the center you would need 5:1. My guess is that the line in the cockpit floor would be roughly equal, while close hauled, with the same real mechanical advantage.
K.C. Walker wrote:In light air on a run, center boom sheeting has less line distance in the air which is nice.
K.C. Walker wrote: Also, I like jibing with center boom sheeting better than with end boom sheeting. The problem with center boom sheeting is getting an effective traveler at reasonable cost and without cluttering up the cockpit.
