Tabernacle install?
Postby K.C. Walker » Sat Nov 07, 2009 12:43 pm
talbot wrote:I took an old elbow wrap (like you get in a drug store for relieving tennis elbow) and put it around the mast stub below the tabernacle. Once the mast is raised, I pull it up around the tabernacle like a little muffler. It seems to soften the edges enough that I haven't had any fouled sheets since. The wrap I had was elastic knit, but I imagine a neoprene wrap would be even more effective.
This is a great idea! And, I'm glad to hear that it works. I have a heavy rubber piece that I Velcro around the tabernacle which does pretty well. However, I was just commenting to my daughter about where I might buy some neoprene to wrap around the mast. I was sort of envisioning a wetsuit sleeve with a zipper. So this idea will save me some trouble!
KC
Re: mast hinge a couple of inches above the cuddy roof
Postby etonline » Mon Nov 09, 2009 10:26 am
Roger wrote:as dannyb9 correctly states, there is a sligh fowrward tilt to the cuddy roof. When you remove the forward pin, and forestay, and allow the mast to hinge back into the mast crutch; it will be level to the boat only if the hinge is a couple of inches above the cuddy deck. That aft end of the cuddy roof has a bit of a lip on it as well, and you don't want your mast resting on this.
I understand the lip issue Roger. But if you use a rear mast crutch or pad the cabin top with a life vest, I don't understand why it would be an issue. Unless you drop the mast, is that the concern?
I saw the pictures of yours in your book this weekend Roger.
But I don't remember did you seal the mast stub in Roger?
etonline
Postby GreenLake » Mon Nov 09, 2009 8:34 pm
The probability that a mast gets dropped is > 0%, unfortunately. Probably wise to limit damage should that eventuality happen.
Users browsing this forum: No registered users and 122 guests
