Corroded Jib Hanks
Corroded Jib Hanks
Postby hriehl1 » Wed Jul 09, 2008 2:18 pm
I have seriously corroded brass jib hanks that I'd like to clean up, but I'm worried that most anything I might do or use to cut the corrosion will stain the jib.
Any ideas? Thanks
hriehl1
any ideas
Postby pjk170 » Mon Sep 07, 2009 8:36 pm
Sorry to bump an old post, but does anyone have any ideas on how to solve this problem?? Is it possible to purchase just the hanks for the jib??
thanks....
pjk170
Postby Peterw11 » Sun Sep 13, 2009 10:50 am
Don't know about not staining the sails, but I'd remove them, get after them with a dremel or a wire brush, and soak them with wd-40
You can buy new brass ones, or plastic ones, From Duckworks Supply.
Peterw11
