Help mast glassed in solid to cuddy roof
Postby Red Ron » Mon Jun 29, 2009 10:32 pm
Hi all
I bought a 1973 day sailor 2 hull # 26508, class#5038 that was in fairly good shape .The PO at some time had broken the mast off, that he replaced with a two piece mast that has a short support with a hinged mast step on top of the cuddy roof, then the mast was fiber glassed solid in the cuddy roof, no partner or hole for the support to pass through .
My problem is I have to much weather helm and unable to properly adjust the mast . I don’t know if the mast step on the cuddy floor was also moved, I am going to cut a new hole in the cuddy roof and need two measurements inside the cuddy cabin , one from the top inside back of the cuddy bulkhead to the center of the hole in the cuddy roof, and one from the inside bottom of the cuddy bulkhead to center of the mast step attached to the cuddy floor. (double click drawing below ) if someone would give me the measurements it will be greatly appreciated happy sailing.
:D
729
blueskys
Ron 1973 DaySailer 11 Mrs Gennie
Hull#26508 Class#5038
Southern Maryland
Red Ron
Postby adam aunins » Fri Jul 03, 2009 1:27 pm
Did anyone ever get you what you needed?
adam aunins
Mast glassed in to cuddy roof
Postby Red Ron » Sat Jul 04, 2009 12:07 am
Hi Adam
Sorry i an slow getting back to you. it was such a nice day here in southern Maryland with 10 nto 15 mph winds, i have been on the Patuxent river sailing all day.
No has given me the measurements yet,if you can help, i would appreciated it.
Thanks Ron :)
blueskys
Southern Maryland
Red Ron
Postby adam aunins » Sat Jul 04, 2009 10:50 am
If pic doesn't come up you can see it in my personal gallery
adam aunins
Postby adam aunins » Sat Jul 04, 2009 10:56 am
I went from the lip to the back of the mast as there was less guess work involved in pulling that measurement for me. If this doesn't get you what you need let me know and I will do what I can for you. http://forum.daysailer.org/forum/gallery/search.php?st=0&sk=t&sd=d&search_id=usersearch&username=adam+aunins&user_id=825
adam aunins
Postby Red Ron » Sun Jul 05, 2009 9:30 pm
Hi Adam
Thats just what i needed i will cut a hole in the cabin top this week and let you know it worked out.
Thanks Ron
blueskys
Southern Maryland
Red Ron
mast
Postby Red Ron » Tue Jul 14, 2009 12:33 am
Thanks to adam aunins who gave me the measurements I needed I cut the hole for mast in the cuddy roof and now I am able to properly adjust the mast.. Took her out for a sail and she handled great with the right amount of weather helm.
Happy sailing :)
blueskys
Southern Maryland
Red Ron
Users browsing this forum: No registered users and 86 guests
