Gas siphon
Gas siphon
Postby kokko » Wed Nov 07, 2012 8:51 am
I siphon my gas tanks dry each season, usually resulting with gas in my mouth. I bought a $4 siphon pump - two tubes and a squeeze bulb - and it was crap. It did not pump from tank to another container and the bulb leaked squirting gas everywhere.
Who can recommend a good siphon pump?
DS1 Truelove
Postby ChrisB » Wed Nov 07, 2012 10:07 am
I had one of the tube and bulb siphons. It didn't leak but I did have to hold my thumb over the end of the outlet tube to "prime" the bulb. Once I got fuel into the bulb it worked fine. I bought it at Wal Mart. Harbor Freight tools has one that looks to be better made than the one I had.
gas siphon
Postby kokko » Wed Nov 07, 2012 10:50 am
I looked at the Harbor Freight Tools siphon online. All agreed that it dissolves when you use it with gas. I wonder if a cheap fuel line is a better bet. I could just cut off the fittings.
DS1 Truelove
Postby PassingWind » Wed Nov 07, 2012 2:39 pm
I bought a fuel priming bulb and line from walmart works like a charm. I dont recall what i paid though.
PassingWind
Postby mike31416 » Thu Nov 08, 2012 8:13 am
My motor is small enough to just turn upside down into a large funnel.
mike31416
Postby GreenLake » Thu Nov 08, 2012 9:41 am
On mine, I usually just tap the two leads together after removing them from the battery. That takes care of any left-over electrons at the end of the season. :shock: :D :D
(sorry, couldn't resist.)
Postby jdoorly » Fri Nov 09, 2012 2:28 am
Holy coulombs Batman, aren't you escared of creating a particle accelerator and getting quarks all over your boat doing that!
Users browsing this forum: No registered users and 52 guests
