Daysailer 3 missing mast-mounted ring to clip halyard ends
I have replaced my Daysailer 2 with a 3, and find that the mast mounted ring to which the halyard ends are clipped when not attached to the sails is missing. I presume that this fitting was abandoned, because it sometimes interferes with the jib when tacking. What alternatives are there for securing the halyards so the fitting end doesn't run up the mast?
