Reefing pics please
I have copied a section of the O'Day book here. But would love a picture of someone having reefed their main to help me make sense of how its supposed to look.
Specifically, where it says :
Sixth lock your
boom back into place by letting the boom go forward and tighten up halyard When
reefed, the boom block for the mainsheet is attached to the roller reefing claw.
Roller Reefing
A "Roller Reefing Claw" is necessary. Your mainsail can be easily reefed, as the boat is
equipped with a spring loaded gooseneck. First remove the block in the middle of the
boom. Second, release the main halyard but keep it under tension. Third, pull the boom
back from the mast so that you can turn it. Fourth, roll the boom either way as you or
your crew lets off slowly on the halyard. The sail will roll on the boom. Fifth, when you
have rolled about 5 or 6 times, you will have reduced your sail area by one third.
Experience will teach you how much to reef under various conditions. Sixth lock your
reefed, the boom block for the mainsheet is attached to the roller reefing claw. To shake
out, just reverse procedure.
Sixth lock your
Roller Reefing
