Is this jib cleat set up correctly?
Postby zeroready » Mon Sep 07, 2020 3:25 pm
As it is, to set the sheet into the cleat I have to pull it forwards, so I wouldn't be able to do it if I were singlehanding and not sitting right up by the cleats.
zeroready
Re: Is this jib cleat set up correctly?
Postby Alan » Mon Sep 07, 2020 3:30 pm
As far as I know, it is set up correctly. That's how mine were before I got new ones. Mounting it backwards in the track doesn't work at all--I've tried it.
The only advantage I can see to this design is that you can uncleat it in a hurry.
Postby zeroready » Mon Sep 07, 2020 7:47 pm
Lol I tried flipping mine around too, definitely did not work. I noticed I have angled flat spots on the CB housing in the center, I've seen others install cleats there for the gib. I think I'll go that route.
http://forums.sailinganarchy.com/index. ... cam-cleat/
Thanks for the clarification!
zeroready
Postby GreenLake » Mon Sep 07, 2020 9:14 pm
Even singlehanding you should sit forward as much as you can. Do you have a tiller extension?
Postby zeroready » Mon Sep 07, 2020 9:50 pm
I do have an extension. Tomorrow is the big day, our first cruise. So I will be able to see how far forward I can get.
zeroready
Postby GreenLake » Mon Sep 07, 2020 10:28 pm
In light winds, no need to cleat the jib. Have fun.
Postby IslandFarmer » Thu Apr 22, 2021 10:21 am
That's just what mine looks like and is a priority to change this year if possible ... a new cleat to put on the existing slider without drilling any new holes. Current system is SO awkward. Rudy Nickerson at D&R Marine told me last fall that he is working to get a new product that will be more satisfactory no matter if you are sailing alone or with crew. Spoke to him again yesterday. Still in progress.
-Cindy
1983 DSII 12250
Stonington CT
IslandFarmer
