jacking up boat to test cb on land
PostPosted: Tue Nov 12, 2019 8:20 pm
by Don
Any suggestions or good ideas to lift the boat
Re: jacking up boat to test cb on land
PostPosted: Tue Nov 12, 2019 9:51 pm
Once you have the boat on any kind of support you can raise it using a 2x4 as a lever. Have a helper add another tire, brick or piece of lumber to your support, lever up the other end the same way and repeat. (You will obviously need a third support for your fulcrum).
Or, if in a garage, rig two loops that you can hoist to the ceiling with a purchase. Useful only if you plan on using the same setup again in the future.
With two - three helpers, you can lift each half of the boat with two people while the third adds another layer to the support on that end. The DS is not *that* heavy.
PostPosted: Wed Nov 13, 2019 12:08 am
by Don
sincere thanks for a simple and efficient way to do it. I have been overthinking the problem for days and since its winter coming on I have the time to give myself headaches
