DS centerboard controls
I recently purchased a '73 Daysailer II (hull #6822) and have one issue that requires advice... the centerboard pennant/controls. After launching her for the first sail, the centerboard would not lower. There is a centerboard pennant (hold the board up line), made of stiff shroud material (1 x 19 wire) but it is quite contorted and bent. There is, however, no line/pennant for lowering and keeping the board down; although there is an opening (with small block) in the top of the centerboard trunk that appears to be for such a line. First, do Daysailers normally have both a "keep board up" line and a "keep board down" line? Second, is the attachment of the centerboard lines/pennants as shown in the accompanying photo standard? Third, I've made a quick drawing to show how I propose to install new centerboard control lines to solve the problem... would you anticipate any problems with the proposed scheme?
Thank you very much for taking the time to help a new DS sailor.
Dana Dahlquist
Dana Dahlquist
