Normal Mast Curvature or Bent Mast?
I was at my CreekFleet shakedown sail the other day and one on the guys commented that my mast had a bend
I never noticed, but there a slight gradual forward curvature to the mast near the spreaders. No kink and no sideways bend to it and she seems to sail fine. I keep the mast in the crutch with the sail slot facing down. I was toying with the idea of turning it over and hanging some weight around the mast near the spreaders to slowly bring it back to a straighter profile.
Question 1: I've read today on the internet that some masts are designed to have some amount of forward curvature for weather helm???. Is this the case with a DSll?
Question 2: If I do need to try and straighten it, would this be a reasonable method? or will I be causing more problems? If that's so, I'll just sail it the way it is unless I hear of some other frugal repair method. Grandma doesn't need to be absolutely !00%, I just want to keep her functional for as long as possible
Any input will be appreciated, Thanks
