Gzachmann wrote:Recently acquired a DS II and noticed that the mast step in the cuddy was loose and the floor under it flexed under pressure. Apparenty the mast support that I saw in photo in another thread has moved or is broken. Has anyone else had this problem? My guess is that I will need to add an access port in the cuddy just to see what has happened to the support post. Any ideas would be welcomed b4 I start cutting.
hectoretc wrote:Gzachmann wrote:Recently acquired a DS II and noticed that the mast step in the cuddy was loose and the floor under it flexed under pressure. Apparently the mast support that I saw in photo in another thread has moved or is broken. Has anyone else had this problem? My guess is that I will need to add an access port in the cuddy just to see what has happened to the support post. Any ideas would be welcomed b4 I start cutting.
Gzachmann - Once you're either used Alan's mirror suggestion, or taken your digital camera, stick it in the cockpit access port and shoot a dozen pictures at various angles and elevations (foreward) so you know what your dealing with, "before you cut" an access port in the cuddy sole, either post back again for more specific information, or look again at the pictures you are already referencing.
There is a floor stiffener (seen at the very top of this picture) that runs left to right under the cuddy sole just aft of the mast base. You would prefer not to cut through that.
Good Luck - Scott
Users browsing this forum: No registered users and 93 guests
