by talbot » Mon May 31, 2010 3:05 pm
If it is indeed the CB cable, know that this is a famous DS II problem. After it became apparent, O'Day began installing shock cord between the mast and uphaul to keep light tension on the cable when the board is down. On my early-verson DS II, I accomplished the same thing by just looping a bungee cord around the base of the mast and hooking it to the eye in the end of the cable.
By the way, it isn't all that hard to haul a DS back onto a trailer on dry ground. The dry ground should be smooth and soft (i.e., a lawn). All you need is a tree to tie the stern of the boat to. Drive the trailer slowly out from under the boat. After you've careened the boat and fixed whatever, right the boat and winch it back onto the trailer. I've done this with the trailer off the vehicle. What happens is the trailer more or less slides under the boat. The hull doesn't actually have to scrape much along the ground.
