by persephone » Tue Aug 25, 2009 11:29 am
While I have not installed a deckplate in that area I can fill you in on what you would find.
I had a Javelin, same construction as a DS2, which at the end of it's life I removed the entire transom. I have pictures at home that I can post or e-mail if you want.
Where the well comes down (near the self bailer) O'day filled the gap between the outer hull and the deck well with a filler putty. There is only a small gap (less than an inch). So you are correct that a drain won't fit right at the center line. Going forward from there I do not believe there are any stringers or supports that run across the boat. The Javelin had stringers running the length of the boat about 1.5 feet out from the center line. They installed the hull drain outside this stringer, thus any water in between the stringers was trapped and could not be drained. On the jav, there was room to install a drain inside the stringer but to the side of the cockpit well. You may be able to do this on a DS2 as well. If so I would install one on either side of the well. With drains from the bilge to outside you can tip the boat up and most of the water will drain out.
Good luck. Let me know if you want some pictures.
