Telltale Placement
Telltale Placement
Postby sidvorak » Fri Dec 05, 2008 2:45 am
So I've got a new jib and now I'm wondering "Where do I put the telltales?" I found some general instructions online, but I'm wondering if there are some specific measurements for the Daysailer that others are using.
Thanks for any help!
sidvorak
standard placement calls for...
Postby Roger » Fri Dec 05, 2008 11:57 pm
Mark the jib luff at the half and each quarter. 6 inches back from this leading edge is where you would place your THREE sets of tell tales.
A further set called steering telltales (for the more advanced sailor) can be placed according to this video clip. If doing this, you can eliminate the lower set of telltales and place them at the 1/3 up 1/3 down along the luff. In this video he separates the starboard and port telltales by a 1/4". I would separate them by 2" with the starboard higher. With the sun behind the sail it is difficult to tell which is which by color, so position separation is key.
http://www.ehow.com/video_2358464_addin ... -sail.html
Postby talbot » Sat Dec 20, 2008 12:22 am
Any advice on telltales for the main sail?
bumping this thread...
Postby JML Avalon » Mon Jul 05, 2010 10:01 pm
Yeah, I need to put on telltales, too, and found the following, which corroborates the placement for jib, gives placement for main, and additional info on sail trim.
"Install telltales on both sides of the headsail about one foot abaft the luff at 1/4, 1/2 and 3/4 intervals. On the mainsail, install leech telltales at each batten pocket, install mid-sail telltales at 1/2 and 3/4 heights."
Source: http://www.jasperandbailey.com/tech/news.html
Now, is a telltale something I can buy, or do I just get some yarn and sailtape?
"Avalon" DSII, #4854
JML Avalon
Postby talbot » Tue Jul 06, 2010 10:00 am
You can buy them. I got mine from my sailmaker, Intensity, but they have them at West Marine, Defender, etc. As you suggest, they are simply yarn stuck to sail tape, so there's no reason you couldn't do it yourself. Get different colors (typically red for port and green for starboard). In certain lighting, that makes it easer to identify which surface of the sail is being affected.
I did not have much luck with my mid-sail telltales on the main, and removed them. But I think I had them too far forward. Maybe I'll try again using the directions you provided. The jib telltales are invaluable.
--Talbot
