I'll be towing my DS2 all over the place.
There are 3 stays the line to raise the main, the line to raise the jib and the topping lift.
As you get ready to raise the mast , these lines and stays become a nightmare.
Does anyone have a secret as to how they store these when traveling so that it doesn't take 20 minutes to get everything separated and in place.
My current plan is to remove each line when I'm done for the day. Then replace each when I sail again.
If you have a an easier way it would be a great help.
Thanks in advance
