Leeway with the CB partly raised
It is my understanding that fixed keel shoal draft boats (Compac 16, 19) will absorb some of the force of the wind in a blow by slipping sideways. Not great for pointing, but a desirable security factor when the winds get big. Do those same factors come into play when the CB is partially raised on a DS? I understand that adding weight to the windward side will reduce heel. But will raising the CB help stability? Or will the lowered resistance of the CB add to the heel?
Any thoughts or experiences is appreciated. Thank you.
