New Owner Question 1; Motor Mount
PostPosted: Thu May 18, 2006 9:12 pm
by hriehl1
Just bought a 1981 DS II. The prior owner simply attached the 2 HP short shaft outboard over the transom with a couple small pieces of plywood to protect the transom itself. Seems sorta crude, but it works OK.
How do you attach your outboard? How does it work for you?
PostPosted: Tue May 23, 2006 1:16 pm
by Orion
I, too, sometimes attach mine directly to the transom. Others here have installed permanent mounting plates on either side of the transom to protect it.
