by mark mirkov » Sun Oct 26, 2008 12:55 am
hiya, roger! thanks for the info on cb repair. by the way, i did receive your book and cd and they are worth their weight in gold!! a few comments about my cb set-up:
the old downhaul is a 3/32" stainless cable anchored in a pocket of the cb with a swedge and epoxy plug, passing through a drilling in the edge of the cb, then aft through an opening in the trunk and a shielded pulley mounted there, then fastened to blocks on the trunk which hold a short length of rope to pull on. I too have the cb repair kit from Rudy, which is made up of 1/8" cable. But this thicker cable binds in the pulley on the trunk, despite my clearancing the shielding on the pulley.
So I have three choices, as I see it:
1) replace the new 1/8" cable with some new 3/32" cable and install the new tangs and cables in the original routing.
2) do the revised downhaul rigging which is used in the later d.s.II's, in which case I guess I won't need the downhaul cable since the revised set-up uses rope instead.
3) use the new 1/8" cable and tang to pass through a newly drilled hole (and pipe-nipple guide) in the trunk forward, and tie off to new blocks, shock cord, and rope in the cuddy.
in short, i am wondering how to proceed with the downhaul revision using the tang and cable from rudy, since all the info i can find says to use rope, not cable. Also, could you comment on the pipe nipple set-up for the downhaul, in this case? It should work the same way as you describe its use for the uphaul, don't you think?
