Motor mount?
Motor mount?
Postby Orion » Thu Jan 27, 2005 3:30 pm
Does anyone know if it is necessary to install a motor mount on the stern to support the weight of an outboard. I believe the DS I bought has had a motor mounted before, but there is no plate.
Orion
no mount on mine
Postby Roger » Thu Jan 27, 2005 10:23 pm
I installed mine right on the transom, but vibration and the motor mount screws will create their own havoc with the gelcoat, so I mounted a epoxy covered plywood plate on the outside, through bolted with three ss bolts through an aluminum plate on the inside of the transom, (port side) to take the abuse. The middle bolt is an eyebolt, to which I padlock the motor. The transom itself is strong enough on its own to handle up to the 8 hp rating for this boat, but you will want to protect the finish.
This link will take you to some pictures of my set up. They are the last two pictures on page 3, but feel free to browse this public site. Click on the thumbnail to see a larger image.
http://groups.msn.com/RogerConrad/shoeb ... ?Page=Last
Postby Orion » Fri Jan 28, 2005 9:18 am
Looks nicely done. Finish? Ha! That's how I suspected a motor has been mounted here before. There are cracks in the finish that are all in two circular patterns--right where motor mounts would go. Thanks for the advice. Maybe I'll start this project when we thaw out.
Orion
Users browsing this forum: Google [Bot] and 10 guests
