DS II/ DS I centerboard differences
Postby sailsedc » Sat Feb 25, 2006 11:44 am
Somebody I know is looking to replace as DS II centerboard and have the opportunity to buy a DS I board. Besides the attachment for raising and lowering are they the same? I have only sailed DS I so I don't have any idea.
Thanks.
C. Lewton
sailsedc
centerboard
Postby gerald » Sun Feb 26, 2006 12:08 am
someone will surely say for sure but Id say they are the same..mine's a ds II but the center board has the square niche where the ds I control arm goes...
gerald
dsII (still no name) # 10169
gerald
Postby Bob Damon » Mon Feb 27, 2006 11:59 am
the overall shape is the same but the DS I board has a square hole for the handle and the DS II has a round hole with a delrin gasket that fits inside to go around the pivot bolt. You would also have to add fittings for the control lines. The location of the hole may not match up as well but you should be able to make it work.
Bob Damon
Class Measurer
