Dirty Bottom
Dirty Bottom
Postby jsbowman6 » Sun Jun 12, 2016 6:30 pm
I got thinking about what was on the bottom of my "new" Daysailers bottom this morning. I remember the previous owner saying he had left it in the water a couple of seasons. I tried a pressure washer and without rubbing it with something course, I couldn't get the stuff to budge. As I cleaned the shower door in our bathroom I thought about the stuff I was using and why the glass door need cleaning. Minerals! So down to the boat I went with Bartenders Friend spray foam and gave it a squirt. The first test I only sprayed a small area and only sprayed it off with a garden hose. The larger area, I scrubbed with a stiff brush on a stick. I think, if I had scrubbed it to spread out the Bartenders Friend and then left it for an hour or so, it might have been even cleaner. But after about 10 minutes I sprayed and scrubbed some and you can see the results.
http://www.lowes.com/pd/Bar-Keepers-Friend-25-4-fl-oz-Foam-Multipurpose-Bathroom-Cleaner/50295221?-_-store_code=2866&cm_mmc=SCE_PLA-_-HomeFashions-_-TraditionalCleaning-_-50295221:Bar_Keepers_Friend&CAWELAID=&kpid=50295221&CAWELAID=320011480004323947&k_clickID=ad01ec34-6329-4715-9053-6e0db4adb692
If you have a better way to clean fresh water deposits, I'd like to hear it, but this worked for me. I also had used muriatic acid on an old power boat years ago, it worked as well, but most of the growth was algae like stuff, so it as stubborn.
dirty bottom small.jpg (232.07 KiB) Viewed 8291 times
clean and dirty bottom small.jpg (159.2 KiB) Viewed 8291 times
clean bottom small.jpg (134.95 KiB) Viewed 8291 times
jsbowman6
