Force of main sail
Force of main sail
Postby Shagbark » Thu Jul 21, 2016 8:14 pm
Went sailing this past weekend in 20+ kts. I don't have a ratchet on the main sheet and I didn't want to cleat the main sheet just in case I had to dump it quickly. Needless to say, that was a lot of work. I'm now convinced on the value of a rachet on the main sheet. I've been researching them but don't know how much m.w.l. I will need. I would like to go with the Ronstan RF56110 but it has a working load of 550 lbs. Will that be stout enough?
Shagbark
Re: Force of main sail
Postby DigitalMechanic » Thu Jul 21, 2016 8:32 pm
I have the Harken 2626 http://www.harken.com/productdetail.aspx?id=4741&taxid=421
It is rated for 500 lbs and does just fine.
DigitalMechanic
Postby Shagbark » Thu Jul 21, 2016 10:07 pm
I came across the Harken 2626 but wasn't quite sure why it would be almost 50% more than the Ronstan. Both are auto ratchets with a becket and swivel head with working loads in the 500+ lbs range.
Shagbark
Postby MookaCB » Thu Jul 21, 2016 10:27 pm
I use a Ronstan RF56530. It is holding up well on my mid boom mainsheet.
MookaCB
Postby GreenLake » Thu Jul 21, 2016 10:54 pm
The 55m Ronstan is the one I use, except I don't have mid-boom sheeting, so mine doesn't have becket or fiddle blocks.
I only get a 90 degre wrap and it proves to be plenty. (The mainsheet I use looks like it's made from "rag-wool" socks, so it's pretty grippy but smooth running).
Postby Shagbark » Fri Jul 29, 2016 5:59 pm
I went with the Ronstan RF56111. Rachet can be turned on or off as well as an automatic mode. Cost $72. Arrived yesterday. I have two concerns with it. 1) the becket is rated for 55lbs. Seems lighter than I would like. 2) reviews said a 180 degree wrap may be too much holding power and the line won't be allowed to play out when released. When I take the boat out, I'll report back on how well it works.
Shagbark
Postby DigitalMechanic » Fri Jul 29, 2016 10:47 pm
I went with the harken, it has less holding power and also because of the auto-ratchets adjustability. I have the adjuster turned down a bit on it to make it have less holding power. When sheeting out, there is always a slip before the ratchet breaks free. But the the main sheet slips out pretty fast even before breaking completely free.
DigitalMechanic
Postby GreenLake » Sat Jul 30, 2016 4:24 am
The little selector on the Ronstans is a bit finicky. Just set it to auto and try it. Auto setting has worked out of the box for me on these, with no need to adjust or disable.
Where do you get the info on the working load for the becket? I find "Load on becket not to exceed block load, i.e., MWL 550 Lbs (250kg)", looks like you or your source dropped a "0" (or factor of 10 here).
Postby Shagbark » Fri Aug 05, 2016 6:35 pm
You are correct GL. The becket is also rated at 551 lbs. I had mistaken the 1 for the 'l" in lbs. damn these aging eyes!
Shagbark
Postby Shagbark » Sun Aug 28, 2016 7:50 pm
Well, I finally made it out for my first sail with the Ronstan RF56111. What a difference the rachet makes. Before it felt like a constant battle with the main; now it's much more enjoyable. I would highly suggest if anyone is out there with a non-ratcheting main sheet, to drop the $$s and pick one up.
Shagbark
Postby GreenLake » Tue Aug 30, 2016 12:32 pm
Cool!
Postby K.C. Walker » Fri Sep 09, 2016 9:24 pm
Shagbark wrote: I would highly suggest if anyone is out there with a non-ratcheting main sheet, to drop the $$s and pick one up.
100% agree!
Postby DigitalMechanic » Thu Sep 15, 2016 9:41 am
Shagbark wrote:Well, I finally made it out for my first sail with the Ronstan RF56111. What a difference the rachet makes. Before it felt like a constant battle with the main; now it's much more enjoyable. I would highly suggest if anyone is out there with a non-ratcheting main sheet, to drop the $$s and pick one up.
Yes!!!
Glad you are enjoying it!
DigitalMechanic
Users browsing this forum: No registered users and 112 guests
