Talbot, the RONSTAN SERIES 40 AP double block only can be rotated to 2 positions by taking the stem pin out and moving it, that's one reason I added a SS chain link in the mix, but may try something with more flexibility. I'm thinking of taking the blocks stem pin out and seeing if the corners got rounded off if the block would simple rotate. I took the boat out yesterday and the halyards stayed put, that main is still hard to pull up. I need to drop the mast and look at what's going on. A lot of the friction is in the goose neck on the boom, it seems to bind in the sail slot, the other issue is when the main is 3 to 5 inches from the top, I think the splice is entering into the pulley and with that part being stiff, the main binds.
So here's a question that comes to mind: how high should the boom be relative to the cabin roof or sail slug entry slot? I may be trying to get the sail too high.
Carl, I've used a dry silicone spray in my sail slot and even squirted each slug as I put it into the slot. It helped a little. Not certain what you mean by "How is the line that supports the end of the mast set up?". If you mean the forestay, it's about 2/3's riveted with a strap to the mast and has a quick disconnect lever thing on the bow.
If I had not had an O'day 22 that was very easy to hand pull the mainsail up and cleat off the halyard, I guess I would just accept how hard the main is to deal with on this one. But I've made it better, just gotta figure out the details. Another thing I need to look at are the pulley sheaves, I replaced them with DR Marine ones and the ones they sent did not have a 1/4" bushing in them like the originals. (I'm still wondering if this mast is original).
