Refinishing Rudder and Cuddy Doors: Epoxy, Varnish, or Both?
Hello,
I've recently inherited a 17' O'Day Daysailer II that's in decent shape but needs some work to get it looking great for this season. Aside from some spider cracking in the gelcoat and a small 4" chunk missing from the floor of the cabin, the boat is structurally in decent shape.
One of my intended projects is to refinish the rudder and tiller which is structurally in good shape but all the varnish is worn off and is starting to show some fatigue on the leading edge. I've seen conflicting reports online and in videos - do I need to epoxy with something like WS 105, or use a marine varnish like spar varnish, or do I first epoxy one coat and then put varnish on top of that? The boat will be in the (salt) water all season, but the rudder pulls out in will stay in the cabin when not sailing.
Also, the boat recently had a new set of doors made for the cuddy, which are completely unfinished. Do those need just a varnish, or epoxy and varnish?
Finally, any tips for doing this sort of work?
Thanks!!
Thanks!!
