Hull Repair
My DS2 sat on its anchor at low tide and got a three inch cut port midships, below the water line. Ground back the cut and found the fiberglass fractured. I can't reach this from inside the hull and there is open space behind the hole.
I am thinking straight West epoxy and layered fiberglass patches, is there a better way? Should I spray some door/window expanding foam inside to provide backing?
Cal
Cal
